跳转到主内容
Lenovo Thinkpad T450s Keyboard Replacement
你所需要的
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo Thinkpad T450s Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: 步骤 4 中的图像 1,2 Lenovo Thinkpad T450s Keyboard Replacement: 步骤 4 中的图像 2,2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: 步骤 5 中的图像 1,1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic covering and detach touch point and keyboard cable.
结论
3等其他人完成本指南。
Nathan Morgan
于11/11/19注册
469 声望
创作了2篇指南
团队
IUPUI, Team S2-G5, Stella Fall 2019 IUPUI, Team S2-G5, Stella Fall 2019 的会员
IUPUI-STELLA-F19S2G5
3 名成员
创作了2篇指南
一条评论
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 102
总计 5,830
