跳转到主内容
Lenovo Thinkpad T450s Fan Replacement
你所需要的
  1. Lenovo Thinkpad T450s Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Fan Replacement: 步骤 2 中的图像 1,1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Fan Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Fan Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
结论
另外一个人完成了本指南。
Murphy Derwent
于04/05/22注册
130 声望
撰写一个指南
团队
IUPUI, Team 2-3, Harley Spring 2022 IUPUI, Team 2-3, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S2G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 37
总计 1,242
