跳转到主内容
Lenovo Thinkpad T450s Bottom Panel Removal
你所需要的
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: 步骤 1 中的图像 1,2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: 步骤 1 中的图像 2,2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 2 中的图像 1,1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 3 中的图像 1,2 Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 3 中的图像 2,2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 1,3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 2,3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 4 中的图像 3,3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 5 中的图像 1,2 Lenovo Thinkpad T450s Bottom Panel Removal: 步骤 5 中的图像 2,2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 3,669
