跳转到主内容
Lenovo Thinkpad T440s Thermal Paste Replacement
你所需要的
  1. Lenovo Thinkpad T440s Thermal Paste Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad T440s Thermal Paste Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Thermal Paste Replacement, Thermal Paste: 步骤 5 中的图像 1,2 Lenovo Thinkpad T440s Thermal Paste Replacement, Thermal Paste: 步骤 5 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the four screws securing the fan to gain access to the processor.
  6. Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 6 中的图像 1,2 Lenovo Thinkpad T440s Thermal Paste Replacement: 步骤 6 中的图像 2,2
    • Lift the fan assembly to gain access to the thermal paste. From here, the thermal paste can be wiped away and replaced. Make sure to only apply new thermal paste to the larger die; don't apply any to the smaller one.
结论
6等其他人完成本指南。
Terelle Montalvo
于10/22/18注册
1,477 声望
创作了8篇指南
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G5
3 名成员
创作了8篇指南
一条评论
I replaced the SSD and decided to replace the heat conductive paste too. It was a good move as the paste had completely dried out. The replacement was effortless and the provided instructions were spot on, confirming my assumptions. Lenovo devices are excellent for self-repair.
Dominik Widmann - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 54
总计 2,702
