跳转到主内容
Lenovo Thinkpad T440s Hard Drive Replacement
你所需要的
  1. Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad T440s Hard Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Lenovo Thinkpad T440s Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the single screw securing the hard drive.
  6. Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Use the metal spudger to lift the hard drive out of it's compartment.
  7. Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 7 中的图像 1,2 Lenovo Thinkpad T440s Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Grab a hold of the hard drive and pull it straight out from the device.
结论
5等其他人完成本指南。
Terelle Montalvo
于10/22/18注册
1,477 声望
创作了8篇指南
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 72
总计 9,722
