跳转到主内容
Lenovo Thinkpad T440s Fan Replacement
你所需要的
  1. Lenovo Thinkpad T440s Fan Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo Thinkpad T440s Fan Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Fan Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Fan Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad T440s Fan Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Fan Replacement, Fan: 步骤 5 中的图像 1,2 Lenovo Thinkpad T440s Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
  6. Lenovo Thinkpad T440s Fan Replacement: 步骤 6 中的图像 1,3 Lenovo Thinkpad T440s Fan Replacement: 步骤 6 中的图像 2,3 Lenovo Thinkpad T440s Fan Replacement: 步骤 6 中的图像 3,3
    • Lift the fan out of it's compartment to gain access to the cable connection, firmly grab the cable and pull it out of it's housing.
结论
6等其他人完成本指南。
Terelle Montalvo
于10/22/18注册
1,477 声望
创作了8篇指南
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 UMass Dartmouth, Team S1-G5, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G5
3 名成员
创作了8篇指南
4条评论
It would be helpful to have something about the fan too!
Where to get it, or at least the model number!
Iraj V - 回复
What about thermal grease?
Oscar Desmonteix - 回复
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor Song - 回复
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
tomwedell -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 61
总计 6,576
