简介
可用去T440s屏幕维修的器材有
- AUO display B140HAN01.2 (FRU: 04X0436)
- LG display LP140WF1 (sp)(k1) (FRU: 04X0626)
我是用一块AUO屏幕更换安装的,你可以在不同的Thinkpad论坛上找到关于LG屏幕质量的讨论,所以在此不评论其质量
你所需要的
在开机时,按下 F1 键进入 BIOS
进入"Config" 菜单然后进入 "Power" 菜单
选择 "Disable Built-in Battery" 即禁用内置电池,并按回车键
在此你会被询问是否继续,选择 Yes
手提电脑会关机,然后把手提电脑的电源拔出
移除外置电池
移除连接器排线
When you remove the back cover, it is important that the adhesive tape remains on the cover, not on the old display. In case your adhesive does not work anymore, you should clean the back panel properly and install new adhesive
组装你的设备,请逆序进行这些指引。
组装你的设备,请逆序进行这些指引。
18等其他人完成本指南。
由衷感谢以下译者:
93%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
What about T440s with touch panel?
I do not possess a touch device, sorry.
Can this be done as an upgrade
You mean from “normal” to touch display? I cannot comment on a touch device…
Thanks for the manual. Just fixed my display and changed to an IPS from a T450s.
I just wanted to add to this manual that I replaced the double sided adhesive from the Display bezel with 3 mm double side adhesive (3M 9448A).
I did not get the Bezel off properly with the old adhesive. 3 meters of the tape were sufficient.
