跳转到主内容
Lenovo Thinkpad Edge E40 RAM Replacement
你所需要的
  1. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: 步骤 2 中的图像 1,1
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: 步骤 3 中的图像 1,1
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: 步骤 4 中的图像 1,1
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
  5. Lenovo Thinkpad Edge E40 RAM Replacement, RAM: 步骤 5 中的图像 1,2 Lenovo Thinkpad Edge E40 RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Pull the two tabs on the sides of the RAM.
    • Repeat on the second stick.
    • Do not touch the gold contacts on the RAM, because that could easily damage the RAM.
结论
DistroHopper39B
于05/30/20注册
406 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
