跳转到主内容
Lenovo Thinkpad E585 Hard Drive Replacement
你所需要的
  1. Lenovo Thinkpad E585 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the marked Screws.
    • Pry the backside of and put it aside.
  2. Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Pull gently on the marked pull tab. If it doesn't come out, pull harder.
    • After you pulled the Hard Drive Dummy out, remove the Connector.
  3. Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • After the second step, you should have the dummy with the mounting hardware removed from the laptop.
    • Gently pull on the side until it comes off.
  4. Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Put your hard drive in the middle of the mounting hardware and align the sides with the holes on the hard drive. Make sure the pull tab is on the upside.
    • Push on it.
  5. Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Connect the connector.
    • Push on the ribbon cable to glue it to the underside.
  6. Lenovo Thinkpad E585 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Finally, align the hard drive and push on the marked end.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 1,002
