跳转到主内容
Lenovo Thinkpad E540 Keyboard Replacement
你所需要的
  1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Thinkpad E540 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  4. Lenovo Thinkpad E540 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  5. Lenovo Thinkpad E540 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  6. Lenovo Thinkpad E540 Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo Thinkpad E540 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
结论
2等其他人完成本指南。
Timothy Sumner
于02/14/18注册
1,046 声望
创作了8篇指南
团队
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S2G5
4 名成员
创作了8篇指南
4条评论
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - 回复
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - 回复
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge -
You forgot the latch underneath the main battery.
Moose Technologies - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 45
总计 10,357
