跳转到主内容
Lenovo Thinkpad E540 Fan Replacement
你所需要的
  1. Lenovo Thinkpad E540 Fan Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Thinkpad E540 Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Fan Replacement, Disassembly of the Back Panel: 步骤 3 中的图像 1,1
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
  4. Lenovo Thinkpad E540 Fan Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Fan Replacement, Fan: 步骤 5 中的图像 1,1
    • Heatsink and fan are connected. You have to remove both at the same time.
    • The heatsink and fan are found on the right side.
  6. Lenovo Thinkpad E540 Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the two 1mm Phillips #0 screws from the fan.
    • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
  7. Lenovo Thinkpad E540 Fan Replacement: 步骤 7 中的图像 1,1
    • To remove the heatsink and fan, pull the fan upwards and towards the center.
结论
2等其他人完成本指南。
Timothy Sumner
于02/14/18注册
1,040 声望
创作了8篇指南
团队
USF Tampa, Team S2-G5, Nance Spring 2018 USF Tampa, Team S2-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S2G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 2,405
