跳转到主内容
Lenovo ThinkPad x120e RAM Replacement
你所需要的
  1. Lenovo ThinkPad x120e RAM Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad x120e RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e RAM Replacement, Back Cover: 步骤 2 中的图像 1,3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: 步骤 2 中的图像 2,3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e RAM Replacement, RAM: 步骤 3 中的图像 1,3 Lenovo ThinkPad x120e RAM Replacement, RAM: 步骤 3 中的图像 2,3 Lenovo ThinkPad x120e RAM Replacement, RAM: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Push the two mounting clips on either side of the RAM away from each other.
    • While doing this step, wear an anti-static wrist strap. This will prevent you from generating static that could damage the RAM module.
  4. Lenovo ThinkPad x120e RAM Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad x120e RAM Replacement: 步骤 4 中的图像 2,2
    • The RAM should now be lifting up at an angle.
    • Slide the RAM stick out in the direction the angle is facing.
    • While installing the new RAM stick, push the stick down at an angle and make sure you secure it with the small clips at both sides.
结论
Jacob Fronzaglia
于10/25/21注册
787 声望
创作了6篇指南
团队
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 296
