跳转到主内容
Lenovo ThinkPad Yoga Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad Yoga Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad Yoga Keyboard Replacement: 步骤 2 中的图像 3,3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: 步骤 3 中的图像 1,3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: 步骤 3 中的图像 2,3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: 步骤 3 中的图像 3,3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: 步骤 4 中的图像 1,3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: 步骤 4 中的图像 2,3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: 步骤 4 中的图像 3,3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the keyboard from the laptop.
结论
2等其他人完成本指南。
Felicia McCarey
于10/28/21注册
299 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G4
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 46
过去 30 天: 254
总计 6,963
