跳转到主内容
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: 步骤 1 中的图像 1,1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 3 中的图像 2,2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 4 中的图像 2,2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 5 中的图像 3,3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: 步骤 7 中的图像 1,1
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 9 中的图像 1,2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 9 中的图像 2,2
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 步骤 10 中的图像 1,1
    • Using tweezers, remove the fingerprint reader from the inset.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 353
