跳转到主内容
Lenovo ThinkPad Yoga 370 Battery Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 370 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 3 中的图像 2,2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 4 中的图像 2,2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 5 中的图像 3,3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad Yoga 370 Battery Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
结论
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
另外一个人完成了本指南。
一条评论
There’s a procedure you must do before removing any of the screws- disable the battery!
Ben Rossington - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 64
总计 5,675
