跳转到主内容
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 步骤 5 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 6 中的图像 2,2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 步骤 7 中的图像 2,2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,028
