跳转到主内容
Lenovo ThinkPad Yoga 14 20FY Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
    • The screws do not come all the way out. Do not force them out.
  2. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 2 中的图像 2,2
    • After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
  3. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Hard Drive: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Once the back cover is exposed, remove the two screws holding the hard drive in place.
  4. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic encasing holding down the hard drive after screws are removed.
    • This is the plastic encasing covering the SATA connection on the hard drive. There will be another plastic encasing that will be required to remove in a later step.
  5. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 5 中的图像 2,2
    • Using two fingers, carefully remove the hard drive.
  6. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the plastic encasing surrounding the perimeter of the hard drive.
  7. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 7 中的图像 3,3
    • This step requires the most precision. Forcefully using the prying tool to remove the SATA connector may damage the hard drive and the connection. Remove the connection slowly to a point where you can safely finish removing the connection with your fingers.
    • Use a nylon spudger to remove the SATA connector from the hard drive.
  8. Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY Hard Drive  Replacement: 步骤 8 中的图像 2,2
    • After the SATA connection is removed, gently pop off the hard drive from its socket.
结论
5等其他人完成本指南。
Richard Terre
于04/19/17注册
243 声望
撰写一个指南
团队
Cal Poly, Team S14-G2, Banghart Spring 2017 Cal Poly, Team S14-G2, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G2
5 名成员
创作了6篇指南
一条评论
jhonson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 5,287
