跳转到主内容
Lenovo ThinkPad Yoga 14 20FY Fan Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
    • The screws do not come all the way out. Do not force them out.
  2. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 2 中的图像 2,2
    • After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
  3. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: 步骤 3 中的图像 2,2
    • Remove all 7 screws.
    • One of the screws is behind a black piece of the plastic.
  4. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of the spudger to push the connector out of its socket .
    • Do not use the wire to pull the connector out!
  5. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 5 中的图像 2,2
    • There is a wire looped around the fan. Use the spudger to pull the wires out of the loop.
  6. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 6 中的图像 1,1
    • Gently peel back a piece of tape in the bottom left corner of the fan.
  7. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: 步骤 7 中的图像 1,1
    • Gently lift out the fan.
结论
jose aguirre
于04/19/17注册
264 声望
创作了2篇指南
团队
Cal Poly, Team S14-G2, Banghart Spring 2017 Cal Poly, Team S14-G2, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G2
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,451
