你所需要的
Turn the device to the side as show in the image. Locate the following 1.5 mm Philip head screws as marked by the red circles in the image, and unscrew them.
Complete this exact procedure for the other side of the device.
With the outer plastic coating now off, the inner screen is the only thing left to pull out. is the actual screen.
With the same tool used in the previous step, loosen the screen from all sides and simply pull it out as shown in the image.
It is at this point that you can replace the device with a new screen.
2等其他人完成本指南。
