跳转到主内容
Lenovo ThinkPad X61 Screen Replacement
你所需要的
  1. Lenovo ThinkPad X61 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Turn the device to the side as show in the image. Locate the following 1.5 mm Philip head screws as marked by the red circles in the image, and unscrew them.
    • Complete this exact procedure for the other side of the device.
  2. Lenovo ThinkPad X61 Screen Replacement: 步骤 2 中的图像 1,1
    • Now that all the screws on the sides of the device are loosened, the out plastic coating of the screen has also become loose
    • Use a tool to pull apart this loosened plastic coating as shown in the image.
  3. Lenovo ThinkPad X61 Screen Replacement: 步骤 3 中的图像 1,1
    • With the outer plastic coating now off, the inner screen is the only thing left to pull out. is the actual screen.
    • With the same tool used in the previous step, loosen the screen from all sides and simply pull it out as shown in the image.
    • It is at this point that you can replace the device with a new screen.
结论
2等其他人完成本指南。
Ryan McCarthy
于03/15/18注册
772 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,052
