跳转到主内容
Lenovo ThinkPad X61 Battery Replacement
你所需要的
  1. Lenovo ThinkPad X61 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Lenovo ThinkPad X61 Battery Replacement: 步骤 2 中的图像 1,1
    • The next step is to simply move the switch from the locked position to the unlocked position.
  3. Lenovo ThinkPad X61 Battery Replacement: 步骤 3 中的图像 1,1
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
结论
2等其他人完成本指南。
Ryan McCarthy
于03/15/18注册
772 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 18
总计 1,112
