跳转到主内容
Lenovo ThinkPad X390 Yoga Battery Replacement
你所需要的
  1. Lenovo ThinkPad X390 Yoga Battery Replacement, Back Case: 步骤 1 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Battery Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Battery Replacement: 步骤 3 中的图像 1,1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Battery Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the laptop by lifting up.
结论
Tanner Baine
于09/03/21注册
423 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 47
过去 30 天: 141
总计 1,502
