跳转到主内容
Lenovo ThinkPad X390 Touchpad Replacement
你所需要的
  1. Lenovo ThinkPad X390 Touchpad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Touchpad Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X390 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Touchpad Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo ThinkPad X390 Touchpad Replacement, Battery: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Touchpad Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad X390 Touchpad Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Touchpad Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X390 Touchpad Replacement: 步骤 5 中的图像 2,2
    • Using your hands, remove the battery from the laptop.
  6. Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,2 Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,2
    • After removing the battery, disconnect the trackpad from the laptop's motherboard
    • Using a plastic spudger, flip up the black plastic cover to release the cable.
    • Use a finger to hold back the cable to make accessing the connection easier.
  7. Lenovo ThinkPad X390 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the four 2.0 mm screws securing the touchpad to the device.
  8. Lenovo ThinkPad X390 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Lift up the bottom portion of the laptop and remove the trackpad.
结论
Curtis Kubacka
于09/28/21注册
261 声望
创作了2篇指南
团队
Clemson, Team 5-1, Hunter Fall 2021 Clemson, Team 5-1, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 61
总计 1,294
