跳转到主内容
Lenovo ThinkPad X390 SSD Replacement
你所需要的
  1. Lenovo ThinkPad X390 SSD Replacement, SSD: 步骤 1 中的图像 1,1
    • Shut down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
  2. Lenovo ThinkPad X390 SSD Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 SSD Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 SSD Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 SSD Replacement: 步骤 5 中的图像 1,1
    • Using your hands, remove the battery from the laptop.
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 SSD Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
  7. Lenovo ThinkPad X390 SSD Replacement: 步骤 7 中的图像 1,1
    • Grip the SSD, and gently pull it directly out of its port.
结论
1指南评论
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
Patrick Timmel - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 127
总计 5,705
