跳转到主内容
Lenovo ThinkPad X390 Motherboard Replacement
你所需要的
  1. Lenovo ThinkPad X390 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Power down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five screws on the base cover.
  2. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X390 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the four 5.2 mm screws from the fan using the Phillips #0 screwdriver.
    • Use tweezers to carefully unplug the fan ribbon cable.
  7. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the eleven 5.2 mm screws from the motherboard using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use tweezers to carefully unplug the four motherboard ribbon cables.
  9. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use tweezers to carefully unplug the black and red harness cables.
  10. Lenovo ThinkPad X390 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Carefully lift the motherboard up and out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 92
总计 1,677
