跳转到主内容
Lenovo ThinkPad X390 Fan Replacement
你所需要的
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X390 Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: 步骤 3 中的图像 1,1
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: 步骤 5 中的图像 1,1
    • Lift the fan up and out and remove it from the device.
结论
另外一个人完成了本指南。
Nick Couch
于09/28/21注册
252 声望
撰写一个指南
团队
Clemson, Team 5-1, Hunter Fall 2021 Clemson, Team 5-1, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 34
总计 846
