跳转到主内容
Lenovo ThinkPad X280 Wi-Fi Card Replacement
你所需要的
  1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently disconnect the two wires that are connected to the Wi-Fi card.
    • They should pop off with minimal force.
  5. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
    • Be careful not to over-tighten the screw when reassembling, should be thumb tight
  6. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
    • Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 44
总计 877
