跳转到主内容
Lenovo ThinkPad X280 Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad X280 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • To begin, ensure that the device is powered off and not plugged into a energy supply.
    • Open the device to where you are directly viewing the screen with the keyboard laying flat.
  2. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using the flat end of the spudger, insert it at the top of the right click button.
    • Pry it up to remove the button.
    • Repeat for the left click button.
  3. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 5 mm screws.
  4. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Using the black spudger tool, gently lift under the plastic where the screws were located.
    • Slide the keyboard towards the screen of the LenovoThinkPad X280 and lift the front edge by hand.
  5. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Gently remove the keyboard from the device and flip it over.
    • It should still be attached with connectors on the far left corner at the top so be careful not to rip or pull the keyboard out.
  6. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the keyboard and trackpad cables locks with the pointed end of the black spudger.
  7. Lenovo ThinkPad X280 Keyboard Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X280 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Gently pull the cables from the rectangular connection site to detach the keyboard.
    • Remove the keyboard.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 125
总计 3,689
