跳转到主内容
Lenovo ThinkPad X260 Internal Battery Replacement
你所需要的
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 步骤 1 中的图像 2,2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 2 中的图像 3,3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 4 中的图像 3,3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 1,2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad X260 Internal Battery Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
结论
Ammarin Sinthana
于07/13/23注册
97 声望
撰写一个指南
团队
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 150
总计 1,343
