跳转到主内容
Lenovo ThinkPad X260 Cooling Fan Replacement
你所需要的
  1. Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: 步骤 1 中的图像 2,2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: 步骤 5 中的图像 1,2 Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: 步骤 5 中的图像 2,2
    • Remove the four 2.9 mm screws that hold the cooling fan in order of 4, 3, 2, 1 using a Phillips #1 screwdriver.
    • Gently lift the plastic retaining flap to disconnect the ribbon cable.
    • The plastic that holds the ribbon wire in place is a black lever on a tan block.
  6. Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Gently remove the wires which run along the fan.
    • Remove the old cooling fan.
  7. Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 7 中的图像 2,2
    • Clean the old thermal paste off of the CPU.
    • The CPU, when clean, should have a glossy black finish.
  8. Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad X260 Cooling Fan Replacement: 步骤 8 中的图像 3,3
    • Apply new thermal paste to the CPU.
    • Place the new fan in position and secure by reatching the screws in the order of 1, 2, 3, 4.
结论
Alexander Webb
于12/06/21注册
193 声望
创作了2篇指南
团队
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 39
总计 494
