跳转到主内容
Lenovo ThinkPad X260 Back Cover Replacement
你所需要的
  1. Lenovo ThinkPad X260 Back Cover Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad X260 Back Cover Replacement, External Battery: 步骤 1 中的图像 2,2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Back Cover Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad X260 Back Cover Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad X260 Back Cover Replacement: 步骤 2 中的图像 3,3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Back Cover Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X260 Back Cover Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X260 Back Cover Replacement: 步骤 4 中的图像 3,3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
结论
Alexander Webb
于12/06/21注册
193 声望
创作了2篇指南
团队
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 359
