跳转到主内容
Lenovo ThinkPad X250 Thermal Paste Replacement
你所需要的
  1. Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 1,3 Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 2,3 Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel.: 步骤 1 中的图像 3,3
    • Unscrew the 8 screws holding the back panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
    • Use a plastic prying tool to release all the clips holding the panel in place.
  2. Lenovo ThinkPad X250 Thermal Paste Replacement, The insides.: 步骤 2 中的图像 1,3 Lenovo ThinkPad X250 Thermal Paste Replacement, The insides.: 步骤 2 中的图像 2,3 Lenovo ThinkPad X250 Thermal Paste Replacement, The insides.: 步骤 2 中的图像 3,3
    • It is recommended to disconnect the second battery too.
    • Unscrew the 4 screws holding the CPU cooler. Disconnect the fan cable by releasing the latch on the connector and pulling the cable out.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton buds or paper towel, but be careful not to go too hard on the CPU.
  3. Lenovo ThinkPad X250 Thermal Paste Replacement, Applying new thermal paste.: 步骤 3 中的图像 1,3 Lenovo ThinkPad X250 Thermal Paste Replacement, Applying new thermal paste.: 步骤 3 中的图像 2,3 Lenovo ThinkPad X250 Thermal Paste Replacement, Applying new thermal paste.: 步骤 3 中的图像 3,3
    • Once you removed the old thermal paste its time to apply new one. This model has a hole in the heatsink so it doesnt need thermal paste applyed on the smaller pad.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
  4. Lenovo ThinkPad X250 Thermal Paste Replacement, Other upgrades.: 步骤 4 中的图像 1,1
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont forget to plug in the second battery before closing the back panel!
结论
4等其他人完成本指南。
Simeon Brankov
于11/08/20注册
6,045 声望
创作了49篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 67
总计 3,660
