跳转到主内容
Lenovo ThinkPad X240 - Hard Disk Drive Replacement
你所需要的
  1. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement, Hard Disk Drive and Solid State Drive: 步骤 1 中的图像 1,1
    • Flip the laptop upside down as shown in the photo.
  2. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 2 中的图像 2,2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
    As mentioned below, if there is an SD card in the reader, the cover will not come off, so make sure to remove it.
    David Huggins-Daines - 回复
  4. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 4 中的图像 1,1
    • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
  5. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 5 中的图像 1,1
    • Disconnect the SATA cable from the hard drive.
  6. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 6 中的图像 1,1
    • Take off the connector by carefully popping its holders out of place
  7. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 7 中的图像 1,1
    • Reconnect the cable to the new Hard Disk Drive
  8. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 8 中的图像 1,1
    • place the connector in order to hold the cable
  9. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 步骤 9 中的图像 1,1
    • Place the new Hard Drive Disk
结论
9等其他人完成本指南。
5条评论
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - 回复
That is true, that'd been a much safer way to do it.
Mahir Max -
Tip for the case screws, they are captive don’t worry about them
Baddo-M _ - 回复
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
Ricky Las Vegas - 回复
If you have an SD card in the SD card reader make sure to remove it before trying to remove the case cover, otherwise it will not come off, and you risk damaging your motherboard if you force it.
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 90
总计 14,982
