跳转到主内容
Lenovo ThinkPad X140e Speakers Replacement
你所需要的
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X140e Speakers Replacement: 步骤 2 中的图像 2,2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 3 中的图像 3,3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 4 中的图像 3,3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X140e Speakers Replacement: 步骤 6 中的图像 2,2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X140e Speakers Replacement: 步骤 7 中的图像 2,2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad X140e Speakers Replacement: 步骤 8 中的图像 3,3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
结论
Dylan Halland
于10/05/16注册
318 声望
创作了2篇指南
团队
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 2,885
