跳转到主内容
Lenovo ThinkPad X140e Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad X140e Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
  4. Lenovo ThinkPad X140e Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • After removing the back panel, locate the hard drive located to the far left. It is distinguishable from other parts based on it's rectangular shape.
  5. Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the four 3.5 mm Phillips #0 screws attached on the four corners of the hard drive.
  6. Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X140e Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Slide the hard drive to the left.
    • Grip the hard drive on both sides and proceed to lift up to remove the hard drive.
结论
另外一个人完成了本指南。
kevin hull
于10/05/16注册
213 声望
创作了2篇指南
团队
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G5
4 名成员
创作了5篇指南
一条评论
How do you reformat the hard-drive? I understand physically replacing the equipment, but how do I reformat it with a windows operating system? My email is amwindham@aol.com.
amwindham - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,701
