跳转到主内容
Lenovo ThinkPad X140e Battery Replacement
你所需要的
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: 步骤 2 中的图像 1,1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X140e Battery Replacement: 步骤 3 中的图像 2,2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
结论
Dylan Halland
于10/05/16注册
318 声望
创作了2篇指南
团队
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G5
4 名成员
创作了5篇指南
一条评论
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 11
总计 960
