简介
Removing the battery is a relatively simple task but is very important to remove power from the laptop in case power shorts any vital components. The x140e battery is a lithium-ion battery, so caution is advised when removing the battery.
你所需要的
Turn off your laptop and unplug the charging cable.
Flip the laptop upside down.
Rotate the laptop so that the battery is facing away from you.
即将完成!
结论
一条评论
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
