简介
If the back cover of your Lenovo ThinkPad X1 Yoga is damaged this repair is recommended. This could include cracks on the back or corners from wear, air flow issues, or if you simply need to access the inside of the computer. This repair can help make your laptop look like new again. This is an easy repair with no special skills required. The only thing to look out for is making sure all nine screws are removed before removal of the cover. Make sure your computer is turned off and removed from the power source before beginning this repair.
你所需要的
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
