跳转到主内容
Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Speakers: 步骤 4 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Speakers: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    $3.99
    购买
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 5 中的图像 2,2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: 步骤 6 中的图像 2,2
    • Use your fingers to remove the speakers from the device.
结论
团队
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 642
