跳转到主内容
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 5 中的图像 2,2
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G3
5 名成员
创作了11篇指南
1指南评论
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 71
总计 8,880
