跳转到主内容
Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 步骤 2 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 步骤 2 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 步骤 5 中的图像 3,3
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 392
