跳转到主内容
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 步骤 2 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 步骤 2 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: 步骤 3 中的图像 1,1
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 51
总计 1,100
