跳转到主内容
Lenovo ThinkPad X1 Yoga (6th Gen) Fan Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to loosen the four 5 mm captive screws.
    • The captive screws will stay attached to the fan as you remove it.
  3. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: 步骤 3 中的图像 3,3
    • Place the pointed tip of a spudger behind the small plastic tab on either side, and "walk" the fan's connector out of its port, alternating between tabs, until the plug disconnects.
    • Lift the fan up and out.
结论
一条评论
Hi, Do you know what is the fan part number? Where did you get the fan from?
hamedabedi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 82
总计 684
