跳转到主内容
Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement
你所需要的
  1. Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Opening the back panel: 步骤 1 中的图像 1,2 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Opening the back panel: 步骤 1 中的图像 2,2
    • Unscrew all screws holding the back panel in place.
    • Use a prying tool to release all the clips and remove the panel.
  2. Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 步骤 2 中的图像 1,3 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 步骤 2 中的图像 2,3 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 步骤 2 中的图像 3,3
    • It is recommended to disconnect the battery.
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan. You can also open it to clean it from the inside.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
结论
另外一个人完成了本指南。
Simeon Brankov
于11/08/20注册
6,448 声望
创作了51篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 55
总计 1,038
