跳转到主内容
Lenovo ThinkPad X1 Extreme Trackpad Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Speakers: 步骤 2 中的图像 1,1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 1.5 mm Screwdriver
    $5.49
    购买
    • Remove the four screws that are holding the trackpad to the Thinkpad using a 1.5 mm flathead screwdriver.
  7. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad X1 Extreme Trackpad Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to release the retaining tab on the trackpad cable connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 44
总计 1,535
