你所需要的
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
即将完成!
结论
