跳转到主内容
Lenovo ThinkPad X1 Extreme Speakers Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: 步骤 2 中的图像 1,1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
结论
Kristen Gismondi
于11/12/14注册
82,722 声望
创作了202篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,432篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 358
