跳转到主内容
Lenovo ThinkPad X1 Extreme SSD Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Extreme SSD Replacement: 步骤 3 中的图像 2,2
    • Using the opening tool, pop out the SSD card and remove it from the device.
结论
另外一个人完成了本指南。
1指南评论
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 60
总计 2,716
