跳转到主内容
Lenovo ThinkPad X1 Extreme RAM Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: 步骤 3 中的图像 1,1
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 16
总计 1,005
