跳转到主内容
Lenovo ThinkPad X1 Extreme Motherboard Replacement
你所需要的
  1. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  2. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of the frame and remove it from the device.
  3. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: 步骤 3 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: 步骤 3 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: 步骤 3 中的图像 3,3
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  4. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 4 中的图像 2,2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  5. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 5 中的图像 2,2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  6. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 6 中的图像 3,3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  7. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
    • Remove the silver plate on top of the charging port.
  8. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 8 中的图像 3,3
    • Disconnect all the ribbon wires from the motherboard.
    • All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
  9. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 9 中的图像 3,3
    • Disconnect the black attachment at the top right corner of the motherboard.
    • Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
    • While maintaining pressure, gently pull on the wire that is connected to it to remove it.
  10. Lenovo ThinkPad X1 Extreme Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently lift the motherboard out of the computer.
结论
2等其他人完成本指南。
Brant Baugher
于02/10/20注册
166 声望
撰写一个指南
团队
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 51
总计 3,445
